I sure wish I was better at event-driven programming, but it just makes my head hurt. I'm thankful as always for the folks in this forum!
I need two buttons that have the following behavior:
turning either button ON turns the other OFF, but:
both buttons can be OFF.
both buttons can NOT be ON.
everything I've tried so far doesn't work.
-eric
another button interaction question
martignasse
hi woodslanding,
do you mean button, or switch ?
cause two buttons can hardly be both ON at the same time...
edit :
for switchs, it could be like that
Hope it help
edit :
Hope it help
