Sub patch visible in ctrl panel
Unread post by cmodica » 20 Feb 2009, 12:11
I want to use a ''Spectral Spectrum'' and a ''Spectral Filter'' in the same patch. I add the ''Spectral Spectrum'' as a SubPatch in my ''Spectral Filter'' Patch. but how can i see the Spectrum in the Control Panel of the ''Spectral Filter'' Patch ?
How can i get the ''Lines Module'' visible in the ''parent control panel'' ?
Thank you
Unread post by senso » 20 Feb 2009, 12:22
avoid sub-patches and try to create a new patch which contains both.
Unread post by grego mondo » 21 Feb 2009, 02:01
is it just a visual or a "processing" advice ?
