I use audio modules to make audio circuitry.
Are there any module to built midi routing.
For exemple i need to patch a midi in and two path, with differents modules or vst, selectable with a switch.
'module/audio/dispatch' have yellow inlet outlet that no transmitting any midi message.
'module/data/' don't seem to be goods ones.
Salutations, cyrille.
how to patch midi
midi message are most often saw as data in Usine ...
here an example of 2 different ways :
Bonjour/hi,
Thanks for your reply and for the sreenshot nay-seven It looks that i can do A/B or B/A paths select with those modules.
I like the nanotron2 to.
