define keyboard range with Midi learn
nofish
Unread post by nofish » 07 Dec 2008, 21:10
I want to create a patch that allows me to define the keyboard range of VSTi(s) with Midi learn.
Like this:
Midi In -> Keyboard range patch -> VSTi.
I want to assign the upper and lower limits of the keyboard range with pressing the respective notes on my Midi keyboard for quickly creating keysplits.
I know there is the Midi range fader remote example in the addon section, but I don't know if I could apply this in my situation (and how to).
Also, I think I can't use a subpatch because I think there's no possibilty on subpatches for Midi learn, am I correct?
Thanks for help.
ethnix73
Unread post by ethnix73 » 07 Dec 2008, 21:57
Something like this perhaps:
Activate the switch (pass hi and pass low) when you want to make a midi learn.
If you can't do any midi learn in a subpatch ( i was not aware of this ), you can put a local interface builder and do midi learn in it...
Seb.Dub
nofish
Unread post by nofish » 08 Dec 2008, 16:38
Hi ethnix,
your suggestion pointed me in the right direction.
Thanks.
