Strange behavior using Miditranspose.script
This script must be probably updated to be used with a sustain pedal.
I'll take a look.
Did you try the Midi Transform module which can also make transposition?
I'll take a look.
yep
this script transpose also the CC number...!!??
if cc64 send with a transpose of +2 CC 66 is send...
waiting for a fix , you can separate the message this way :
use the midi cc filter patch ( midi / miditools ) and set cc number to 64
Ah! ok thanks for the alternative method, works great! BTW the Midi Transform module exibits the same behavior. Thanks for helping a newbie.
Skully
Skully
i'd recommend to try the midi transposer scripts in the addon section.
bsorks solution is better if u want to transpose notes in realtime - u wont get hanging notes.
u can also try one of my ripoffs that have slightly different design.
you're right amiga909 , but skully don't have access yet to addons...( not gold members..)
Im really happy with Usine so far. I will probably buy it soon. When I click "buy" on the site it takes me to a French Pay Pal site. How much in US dollars is Usine? How to purchase from Pay Pal in English? Oh yes and one more question how is the word "Usine" pronounced?
Skully
Skully
if you have a paypal account , i suppose if you log to it you'll have it in english...? you can also try the credit card link...When I click "buy" on the site it takes me to a French Pay Pal site. How to purchase from Pay Pal in English?
today , it's about 98.6 US dollar ( http://www.mataf.net/fr/conversion/monnaie )How much in US dollars is Usine?
usine [ yzin ]Oh yes and one more question how is the word "Usine" pronounced?
