Strange behavior using Miditranspose.script
skully
Unread post by skully » 28 Jun 2009, 02:33
When i use this between my midi in and a VST instrument my sustain pedal quits working or works only when the transpose is set to "zero". I am a newbie so i might have setup it up wrong, can someone help?
Unread post by senso » 28 Jun 2009, 10:53
This script must be probably updated to be used with a sustain pedal.
I'll take a look.
Did you try the Midi Transform module which can also make transposition?
Unread post by nay-seven » 28 Jun 2009, 11:30
yep
this script transpose also the CC number...!!??
if cc64 send with a transpose of +2 CC 66 is send...
waiting for a fix , you can separate the message this way :
use the midi cc filter patch ( midi / miditools ) and set cc number to 64
skully
Unread post by skully » 28 Jun 2009, 18:35
Ah! ok thanks for the alternative method, works great! BTW the Midi Transform module exibits the same behavior. Thanks for helping a newbie.
Skully
amiga909
Unread post by amiga909 » 28 Jun 2009, 23:05
i'd recommend to try the midi transposer scripts in the addon section.
bsorks solution is better if u want to transpose notes in realtime - u wont get hanging notes.
u can also try one of my ripoffs that have slightly different design.
Unread post by nay-seven » 28 Jun 2009, 23:40
you're right amiga909 , but skully don't have access yet to addons...( not gold members..)
skully
Unread post by skully » 29 Jun 2009, 16:39
Im really happy with Usine so far. I will probably buy it soon. When I click "buy" on the site it takes me to a French Pay Pal site. How much in US dollars is Usine? How to purchase from Pay Pal in English? Oh yes and one more question how is the word "Usine" pronounced?
Skully
Unread post by nay-seven » 29 Jun 2009, 18:40
When I click "buy" on the site it takes me to a French Pay Pal site. How to purchase from Pay Pal in English?
if you have a paypal account , i suppose if you log to it you'll have it in english...? you can also try the credit card link...
today , it's about 98.6 US dollar ( http://www.mataf.net/fr/conversion/monnaie )
usine [ yzin ]
Users browsing this forum: No registered users and 37 guests
