Samplers again
Question 1 : when triggering a sampler with midi, is it possible to set a value so that the sampler play the full sample, even if the midi keybord key is released. My intention was to experiment with a set of samples with various lengthes and triger them with a midi sequence or keyboard, in a random order.
Question 2 : actually, I can't get the sampler to play several samples at the same time, it works with only one voice. Normal ?
You know my name (look up the number)
something like this ..?:
this way you can choose the midi note who play the sample and even if you replay the same note , it works...
of , course the sampler is set to " play button"
second question : yes it's normal ...
Thanks yan, but I don't think it's what I need. I just want to build the "sampleur aléatoire" that I have described on your forum.
So each time I press the same key (C3 for instance), the sampler plays a random sample from the sample set, but plays it fully.
so just with this patch , if you set the "mode" inlet sampler to random , it do exactly what you say...?
Ok, but how do I found the small elements in the middle ? (sorry but I never tried this kind of things)
edit : ok, I found all except the element = where is it ?
edit 2 : ok I find all
math / logical / A=B
yes, thanks - now if works, but i'm not satisfied - I tried the loop mode, not bad, but I can't control the flow
the problem is that the sampler can't ply several waves at the same time
so bad
so bad
what do you mean..?but I can't control the flow
just add others sampler module linked the same way...?the problem is that the sampler can't ply several waves at the same time
I mean that I can't trigger manually the samples, they play automatically one after one in the loop mode.
if you want play manually , the first patch is ok..
if you want use loop mode..so...it's loop mode.."grin"
sorry..don't follow you..
OK nay, I did a mistake yesterday night, it works. Now if I want to feed the input of the sequencer with a midi sequence or a midi vst, what do I have to add ?
just made the patch you need : i mean here :
midi in -->piano roll-->your sampler or vsti
save this as a patch"my midi.pat "
then drag and drop this patch on a track of the sequencer...
is this what you mean..?
yes, I'm in progress thanks to you ! cheers !
Users browsing this forum: No registered users and 126 guests
