1. How do I trigger a sample in the Sampler that would continue to play for as long as I`m pressing the key, not as one shot
2. How can I assign just one key (middle C for example) that would trigger a sample in the Sampler and ignore all other keys
10nX
2 questions (triggering a sample)
hello
beter thant a 200 lines post, you will find some examples in the add-on section:
Sampler Trigg examples.zip
I hope it can help.
I hope it can help.
10nX
the "Play as long is pressed" example worked gr8 but I couldn't make any sound from "Play only on Note num" example, what am I missing?
lo,
the second example works when you press the keboard key 'A' (n? 60).
Insteed of the Keyboard2Midi sub patch Use a Midi in module and choose the note you want to use as a trigger with the 'note' fader.
Maybe the sample file in the sampler is missing on in you computer? Load another one?
Users browsing this forum: No registered users and 91 guests
