It must be very simple but I can not find.
How to convert values from 0 to 1 with values ranging from 0 to 127 ?
marcelvincent
there are severals methods, but the simplest must be just add a AxB module, link your input to A and set B to 127, then add trunc (booth math modules)if needed to keep only integer. Or there are several tools called "change scale" in data/data manipulation that will let you specify min and max.
marcelvincent
Thank you for your help. everything is ok now.
Try to make a Usine patch for my sound table !
Users browsing this forum: Google [Bot] and 89 guests
