I've a range fader. I'd like to keep the defined range and 'pitch" it up or down with only one knob. I'd like the range fader update when I pitch it with the knob. i also want the knob update if i move the range fader. How to do? any idea?
Range fader question.
something like this...?
b= difference between min and max position ...
try it more easy...
hope it's what you ask
try it more easy...
Exactly what i want. I also need a math teatcher ...
Thanks you
Thanks you
