how to remote the BFC-2000
daviche
Unread post by daviche » 18 Nov 2008, 17:48
I successfully use the BFC 2000 midi controller with USINE, but I can't find the way to remote it. I can control USINE, but USINE doesn't seem to be able to control the BFC. The faders don't move when they should.
Did I miss something ?
Thanks !
DC
Composer - guitar player
Dell INSPIRON 16 5645
Windows 11
RME Fireface UC - EVO 8
Unread post by SylvainT » 18 Nov 2008, 18:12
Hello Daviche,
In the setup, midi out, you had to choose the remote, the BFC2000
And on each midi learn, you had to choose to send remote (ctrl-clic on the fader, dialog box)
Hope it works better
amiga909
Unread post by amiga909 » 18 Nov 2008, 23:53
if you press 'U' in the left upper corner, the bcf will be updated (if the params are set as daviche said)
for further refinement: there might occur cases when ur bcf wont be updated automatically. for example if you deactivate a track or if you change the preset of a vst. if u need help here, just ask.
Users browsing this forum: No registered users and 97 guests
