Hi again, since the latest version of Usine, I believe it's Usine4, I load the audio to midi patch, set the latency and midi output channel, and it works, but after say 30 seconds my computer freezes and I have to manually restart it.
Also, I went to set latency today with the latency fader all the way at the bottom left of the audio to midi schematic, normally I just press max and type in 5 and press enter, but today it was a grey box and above it said error every time I pressed it.
Is this a bug? I'm using it in Reaper, with Vista 32-bit. Thanks.
Audio to midi freezes computer within seconds
- senso
Not really normal.
did you try to disable the dual core optimization in reaper (just to try if it comes from that point).
RunBeerRun
It seems ok now, my dual core was set to use only one core, I switched it to both and it ran fine.
Although the previous version I'd been using, 3.68f, ran fine on the one core setup.
