Audio to midi freezes computer within seconds
RunBeerRun
Unread post by RunBeerRun » 26 Oct 2008, 01:04
Hi again, since the latest version of Usine, I believe it's Usine4, I load the audio to midi patch, set the latency and midi output channel, and it works, but after say 30 seconds my computer freezes and I have to manually restart it.
Also, I went to set latency today with the latency fader all the way at the bottom left of the audio to midi schematic, normally I just press max and type in 5 and press enter, but today it was a grey box and above it said error every time I pressed it.
Is this a bug? I'm using it in Reaper, with Vista 32-bit. Thanks.
Unread post by senso » 27 Oct 2008, 08:53
Not really normal.
did you try to disable the dual core optimization in reaper (just to try if it comes from that point).
RunBeerRun
Unread post by RunBeerRun » 27 Oct 2008, 18:14
It seems ok now, my dual core was set to use only one core, I switched it to both and it ran fine.
Although the previous version I'd been using, 3.68f, ran fine on the one core setup.
Users browsing this forum: No registered users and 36 guests
