Quantizing a Button Press
Kaspar
Unread post by Kaspar » 12 Aug 2008, 16:09
After a long hiatus, I'm working again on my sampler patch/workspace.
I've found now, that I need to quantize the rec on/off button press on a sampler (such as in Multiplayer X5) to the nearest division of the current tempo.
How can this be made?
Thanks!
Unread post by senso » 12 Aug 2008, 19:41
in the patch "Samplers/Bar recorder (Sync)" of the library you'll find a subpatch called Quantize Data, which quantize a data flow.
perfect to connect your rec btn ?
Kaspar
Unread post by Kaspar » 12 Aug 2008, 22:02
I'm not sure if I did everything right but by adding this patch, the performance becomes a bit iffy (crashing).
I'm using Usine VST version in Reaper.
When I try to erase this wire (see link), I get an error in Usine and Reaper crashes.
http://stashbox.org/183605/usine_vst_in ... _crash.png
Actually I had a few crashes yesterday also with no obvious cause.
Not sure if there's something wrong in my setup or Usine doesn't like Reaper or vice versa :)
So, is the patch correct at least?
Maybe ask around in Reaper forums to see if anybody else is having similar issues?
Unread post by nay-seven » 13 Aug 2008, 00:34
just try this config with reaper
no problems here..
i can delete without problems and no difference in performance
you said you have some crashes yesterday
so maybe the problem is not here...
Kaspar
Unread post by Kaspar » 13 Aug 2008, 07:48
OK, good that Reaper and Usine can work together.
But not so good that I don't know what the problem is :)
I'm not sure how to test it, maybe make the setup as simple as possible and see if that helps?
Right now I have many instruments routed in Reaper to Usine.
Also I have a guitar processor pedal sending MIDI CC-s to Usine (for controlling the rec buttons).
So, I think I'll ditch all of the above, insert just USINE with this Workspace on one track, without any MIDI controllers etc and play with it for a while.
Then...
Is there something in the preferences I can adjust?
I have the dual core optimization on, but I have a quad core...
Unread post by nay-seven » 13 Aug 2008, 11:58
yes , i think it's the better way to analyse problems , step by step...
about quad core , can't tell you , you have to wait for the boss...;-)
Kaspar
Unread post by Kaspar » 13 Aug 2008, 16:19
Well, no luck going simple.
I had a crash to desktop without a warning (I was deleting a wire) in about 10 min of working.
So, now I'll try the stand alone version.
Kaspar
Unread post by Kaspar » 13 Aug 2008, 17:39
Standalone version of Usine works fine.
Seems that only the VST doesn't play well on my system for some reason.
Unread post by senso » 13 Aug 2008, 19:51
I develop Usine Vst with Reapr, so normally it should work.
By experience I know that you can temporary disable the dual core optimisation, just to see if it comes from this point.
I'll take a look in september (currently I take a summer break...).
Kaspar
Unread post by Kaspar » 14 Aug 2008, 00:12
Thanks for the tip.
Have a great vacation!
I'll practice my patching until then.
nofish
Unread post by nofish » 30 Aug 2008, 21:33
Not sure if you still have problems with this, as the post is a bit old already.
Just wanted to mention that I was trying to do the same (quantize button press) and I found this post by bsork which was exactly what I was looking for:
"You'll find the quantize options both as items on the right-click ("context") menu that pops up for the switches and buttons, as well as a column in the MIDI/Key learn lists for each patch and the global remote."
Hope it helps
Kaspar
Unread post by Kaspar » 31 Aug 2008, 12:41
Thanks!
My main problem right now is that the VST version doesn't like my system for some reason.
But that's another topic.
Users browsing this forum: No registered users and 57 guests
