Plugins Waves & Usine ?
Plaf
Unread post by Plaf » 15 Jun 2008, 17:50
Do you know how to use Plug ins Waves with Usine ? Because when I tried to use them it said a .dll is missing...
Vincent
Unread post by Vincent » 16 Jun 2008, 02:18
Plaf wrote:Do you know how to use Plug ins Waves with Usine ?
Hello plaf, and welcome here!
As Nay-Seven suggested, you can see that it was my question first!
You'll find shell2vst there, and some french explanation there, it's my answer on AF.
Note that this stuff will change your VST Shell into as many *.dll as you have in your shell. Maybe should you avoid to leave them in the same VST folder, since the soft you usually use with the shell VST will recognize them twice and make a very long and very boring list...
Hope it helps.
vincent michel
composer & novelist
Plaf
Unread post by Plaf » 28 Jun 2008, 01:12
Yes it does !
Thanks.
