We have a MIDI device that sends double-precision pitch bend (14-bit data).
We therefore need to take the MIDI code 224 and combine Data1 and Data2 to reconstruct the 14-bit value.
We would like to do this by performing a 7-bit bit-shift (or multiply by 128) on Data2 and add it to Data1.
How can we do this?
thank you
GR
14 bit MIDI data
Hi Gwennaelle,
multiplying by 128 and add to data1 is a good start, but needs a little bit more tweaking, see the patch !
Merci Olivar, je teste ça avec le materiel, et te dirai
Bonne journée
Bonne journée
