Dynamicly changing mapper values
Unread post by grego mondo » 27 Sep 2025, 19:59
Hello all
I'm having an Array to change several mapping out values from a "mapper values" module
it looks like if the Array changes the mapper value won't use the new output values unless I trig his bypass (on & off)
Ever experienced that ?
Is it a bug or am I missing something ?
Take care
Unread post by oli_lab » 27 Sep 2025, 22:37
Hi
can you post a patch ?
if you look at the values in the setting window, they don't update very often to save the CPU, check values on a wire.
Unread post by grego mondo » 28 Sep 2025, 09:50
Here's my trick
when you don't let pass the "trig bypass" mapper won't update value
Dyn Mapped Values.pat
(29.61 KiB) Downloaded 292 times
Unread post by oli_lab » 28 Sep 2025, 17:41
only a change on the "in" input trigger a calculation of the input, so, if you want to change the "out values" on the fly, you'll need to have the datas to change at the input "in"
At last we can guess you're working on a sequencer :evil:
Unread post by grego mondo » 28 Sep 2025, 18:33
thanks for the tip
Well it's more something of a deep subpatches
Unread post by oli_lab » 30 Sep 2025, 22:21
although, if your "in values" are always 0,1,2,3,4...n, you can do that :
Unread post by grego mondo » 01 Oct 2025, 09:58
clever
Users browsing this forum: Google [Bot] and 22 guests
