Dynamicly changing mapper values
Hello all
I'm having an Array to change several mapping out values from a "mapper values" module
it looks like if the Array changes the mapper value won't use the new output values unless I trig his bypass (on & off)
Ever experienced that ?
Is it a bug or am I missing something ?
Take care
Take care
Hi
can you post a patch ?
if you look at the values in the setting window, they don't update very often to save the CPU, check values on a wire.
Here's my trick
when you don't let pass the "trig bypass" mapper won't update value
- Dyn Mapped Values.pat
- (29.61 KiB) Downloaded 289 times
only a change on the "in" input trigger a calculation of the input, so, if you want to change the "out values" on the fly, you'll need to have the datas to change at the input "in"
At last we can guess you're working on a sequencer
thanks for the tip
Well it's more something of a deep subpatches
thanks for the tip
although, if your "in values" are always 0,1,2,3,4...n, you can do that :
clever
