Midi out from script looks good, but doesn't show up on cable
Unread post by woodslanding » 28 May 2025, 21:49
The midi seems well-formed enough to display correctly in the inspector for the script, but nothing comes out the midi output cables.
The data outs work fine....
I feel like maybe an array isn't initialized somewhere? But I can't spot anything.
THANKS!
-e
Code: Select all
const MIDI_TAGS = ['fs1-leslie','fs2-tapRec','fs3-sustain','fs4','mod','vol','ped2','exp'];
const MIDI_CCS_IN = [28,27,26,25,1,7,11,12];
const MIDI_CCS_OUT = [28,27,64,25,1,7,11,12];
var midiIN   : Tparameter;
var ccMidiOUTs,ccValOUTs,ccINs  :     array [0..length(MIDI_TAGS)]  of Tparameter;
// Global variables
var i,m            : integer;
var midiInCount    : integer;
var midiOutCounts    : array [0..length(MIDI_TAGS)] of integer;
var midi : TMidi;
var ccTarget   : integer;
var ccNum  : integer;
var ccVal : single;
var invert : boolean;
procedure init;
begin
    midiIN := CreateParam('midi in',ptMidi,pioInput);
    for i := 0 to (length(MIDI_TAGS) - 1)  do
        ccMidiOUTs[i]:= CreateParam(MIDI_TAGS[i] + ' cc ' + intToStr(MIDI_CCS_IN[i]),ptMidi,pioOutput);
    for i := 0 to (length(MIDI_TAGS) - 1)  do   ccValOUTs[i]:= CreateParam(MIDI_TAGS[i],ptDataField,pioOutput);
end;
// main proc
procedure process;
begin
    midiInCount := GetLength(midiIN);
    if midiInCount > 0 then
    begin
        for i := 0 to length(MIDI_TAGS) - 1 do midiOutCounts[i] := 0;
        for m := 0 to midiInCount-1  do
        begin
            midi := midiIN.asMidi(m);
            ccNum := round(midi.data1);
            begin
                ccTarget := MIDI_CCS_IN[i];
                if ccNum = ccTarget then
                begin
                    midi.data1 := MIDI_CCS_OUT[i];
                    ccMidiOUTs[i].asMidi(midiOutCounts[i],midi);
                    midiOutCounts[i] := midiOutCounts[i] + 1;
                    ccVal := (midi.data2)/127;
                    ccValOUTs[i].asFloat(ccVal);
                end;
            end;
        end;
        SetLength(ccMidiOUTs[i],midiOutCounts[i]);
    end
    else
    begin
        SetLength(ccMidiOUTs[i],0);
    end;
end;
Unread post by woodslanding » 29 May 2025, 23:12
fixed:
Code: Select all
var ccMidiOUTs,ccValOUTs,ccINs  :     array [0..length(MIDI_TAGS) - 1]  of Tparameter;
// Global variables
var i,m            : integer;
var midiOutCounts    : array [0..length(MIDI_TAGS) - 1] of integer;
var midi : TMidi;
var ccVal : single;
procedure init;
begin
end;
// main proc
procedure process;
begin
    begin
        begin
            begin
                begin
                end;
                        SetLength(ccMidiOUTs[i],midiOutCounts[i]);   //FIX
            end;
        end;
    end
    else
    begin
    end;
end;
Users browsing this forum: No registered users and 32 guests
