Hi all.
Is there a way to show in a patch a big audio master out Vu-meters ?
thank you
Show big audio master out vu-meters
there's a module called "master vu-meter" for that purpose
I tried with Audio VuMeter Module but it didn't work as expected.
It is ok with Fader Module instead of Audio VuMeter Module.
Audio VuMeter is expecting an audio signal to its input, that's why it doesn't react correctly.
But I tried to use a "Flow to audio rate" module and it also doesn't work. I thought this module was made for this.
Isn't it its function?
ok, I've understood my mistake... If we use "flow to audio rate " module we need to change Master Vu's scale to linear...
and it works well:-)
You're right, it works fine with "flow to audio rate " and change Master Vu's scale to linear.
Great, thank you.
Great, thank you.
