Reset sends
Reset sends
Unread post by Gilsornette » 28 Oct 2023, 18:03
I use a lot of "sends" from one rack to another, and I often apply a controller remote to them.
And sometimes I have suprises when loading a workspace with one of these sends that has been saved at full...
Is there a way to send a reset to these sends on the opening of the wkp?
Thank you in advance.
Unread post by oli_lab » 01 Nov 2023, 08:42
Maybe you could reset whatever is producing the data going in the bus ?
reset on init.PNG (4.51 KiB) Viewed 30419 times
Unread post by Gilsornette » 02 Nov 2023, 16:41
Thank you for the advice but I'm not using busses, only "rack to rack" sends.I don't know if it's clear.
Unread post by oli_lab » 06 Nov 2023, 13:22
Oh, I see.
What I do:
When having multiple patches in a rack that I with to switch on an off, I make a top patch with all the controls then send them to the various patches
Home it hélas
Unread post by Gilsornette » 06 Nov 2023, 15:04
Hello again,
I understand this and use it also when needed, but in this case I want the sends (in the rack output) to be reseted.
And it seems maybe not possible...
Unread post by cmodica » 07 Nov 2023, 09:01
It is true that the ON/OFF states of the sends output in the rack are not stored in the Rack Preset.
The gain, mute, solo, pre state are stored in the Rack Preset but not the ON/OFF.
It should be a good suggestion for the future update!
Unread post by SylvainT » 09 Nov 2023, 10:06
You can find a workaround with switches and binds.
Then, I answered in the other post.
Best
Unread post by cmodica » 09 Nov 2023, 14:13
Yes, i had forgoten that but i used switches and binds for this kind of thing.
Unread post by Gilsornette » 10 Nov 2023, 08:45
@cmodica and Sylvain T: thank you for your help. For now , I'll manage with switches and binds.
