script contest
joffo78
script contest
Unread post by joffo78 » 26 Apr 2023, 15:15
Hello .
I'm trying to learn about scripting.
To start I opened the script
simplest callback example which displays the index of the last input whose value has been modified.
I would like to :
1) to be able to add an output that would display the value of the last modified input
2) to reproduce the same script but with an array input.
Thank you to enlighten me.
Here attached the script :
Code: Select all
//Simplest Callback exemple: check wich in changed
var In1 , In2 , In3 : Tparameter;
var inputChanged    : Tparameter;
var ChangedValues   : Tparameter;
// Init is started on script compilation to create the in/outs
PROCEDURE INIT;
BEGIN
  In1:= CreateParam('Input1',PtDataField,pioInput);
  In2:= CreateParam('Input2',PtDataField,pioInput);
  In3:= CreateParam('Input3',PtDataField,pioInput);
  InputChanged:= CreateParam('InputChanged',PtDataField,pioOutput);
  InputChanged.Min(0);
  InputChanged.Max(2);
  ChangedValues:= CreateParam('ValueChanged',PtdataField,pioOutput);
END;
// Callback procedure
// inputs have an id (n) from first (top) to n last, the callback proc
// scans the inputs to detect changes,
// and notes the index if detecting one.
// that will allows to launchs different process depending on wich kind of
// inputs changed
BEGIN
  if n<3
  then inputchanged.asInteger(n);
END;
Unread post by senso » 02 May 2023, 09:12
Something like that ?
But I'm shure that you can do that very efficiently with simple modules ?
Code: Select all
const SIZE_ARRAY_MAX = 1024; // max size of array inputs
const NB_INPUTS = 3;
type TmemoArray = array[0..SIZE_ARRAY_MAX-1] of single;
var Inp : array [0..NB_INPUTS-1] of Tparameter;
var ValueChanged   : Tparameter;
var ArrayIndexChanged : Tparameter;
var memoArray : array[0..NB_INPUTS-1] of TmemoArray;
PROCEDURE INIT;
var i : integer;
BEGIN
  for i := 0 to NB_INPUTS-1
  do Inp[i] := CreateParam('Input'+inttostr(i),PtArray,pioInput);
  ValueChanged:= CreateParam('ValueChanged',PtdataField,pioOutput);
  ArrayIndexChanged := CreateParam('ArrayIndexChanged',PtdataField,pioOutput);
END;
// Test changes
Procedure TestChanged(N:integer);
var mx,i : integer;
var v : single;
BEGIN
   mx := minI(SIZE_ARRAY_MAX,inp[n].length);
   for i := 0 to mx-1
   do begin
      v := inp[n].asArray(i);
      if memoArray[n][i] <> v
      then begin
         ArrayIndexChanged.asinteger(i);
         ValueChanged.asfloat(v);
      end;
      memoArray[n][i] := v;
   end;
END;
BEGIN
  if n<NB_INPUTS
  then TestChanged(N);
END;
joffo78
Unread post by joffo78 » 03 May 2023, 10:50
Thank you senso.
i choose to do that by script only for learning.
