I'm planing to record a dmx stream (and play it later), how should I do ?
DMX recorder
DMX recorder
Hi
I guess you need some sort of recorder that can record 8 bit data.
Midi recorder is not good as it is 7bit
But the event recorder module might do the trick.
maybe you could create a recorder with read/write text file ?
a DMX frame is an array [512] of bytes
