Hello to all of you.
1- Is there any way to save the group of Devices with a project?
I have several projects at the same time that use different devives. For each project I save a group of devices that I load according to the project used.
I would like this device group to load automatically when I open the project.
Is this possible?
2- Is there a way to save the HH audio configuration with each project?
In the same way, my audio input/output configuration varies from project to project. Sometimes I use only inputs 1 and 2 and outputs 1-2, sometimes I use inputs 3-4-5 and ADAT outputs 1 to 8, etc.
So for each project I have to reconfigure the inputs and outputs of the HH audio setup.
Is it possible that these configurations are saved with the project?
3- Is there a way to read the name of the device group loaded in the Devices window title ?
Maybe this message should be in the suggestions part of this forum ?
Thank you very much.
questions about save setup and devices
In HH we took the decision to separate setup from projects so no way to do that.
But remember that Usine is a portable application so you can just copy + rename the Usine folder (or .app on MAC) and have several instances of Usine installed on your computer. Each instances has its own setup.
Personally I use this method, very efficient to be sure to retrieve proper settings on each project (not only audio).
I understand and i will test with several instances of Usine. It seems to be the solution for me too.
