A quick question. The Panic button that sends all notes off on all midi channels is quite small.
What is the simplest way to have a larger panic button wherever you want in the workspace ?
Simon.
large panic button
There's an inlet PANIC in the Module/Interface Control/Usine Panels/Usine Master Settings
that allow you to control it from any button or bus ...
Hope it helps
Hope it helps
