cursor and matrix
cursor and matrix
Unread post by Gilsornette » 03 Jul 2022, 19:53
I was wondering if it was possible to have a "point" cursor with a matrix module instead having a vertical or horizontal moving line?
Which means triggering only one cell instead of several (from a row or a line). It's to be used with a 8x8 matrix .
Thank you for your help
Unread post by rlgsbt » 04 Jul 2022, 08:41
Hi GIlsornette,
In MotionKit, you could adapt the "Cells" workspace. It uses XY busses to control the matrix (with smooth and release).
Unread post by Gilsornette » 04 Jul 2022, 12:01
Hi rlgsbt,
It's a very good idea. I'll have a look at it. Thank you!
Users browsing this forum: Google [Bot] and 24 guests
