bi directional knob
GenCode
bi directional knob
Unread post by GenCode » 13 May 2022, 10:57
I was hoping someday could explain . I can control VST Parameter by connecting knob to parameter on VST Panel but want to do reverse control . i want to control knob from VST . by moving knob on actual vst to control knob attached to VST .i know its possible but can't work it out
i made shord video for better illustration
GenCode
Unread post by GenCode » 13 May 2022, 10:58
/Users/gencode/Desktop/QuickTime recordings/Screen Recording 2022-05-13 at 09.41.32.mov
GenCode
Unread post by GenCode » 13 May 2022, 11:04
here is video
Screen Recording 2022-05-13 at 09.41.32 (video-converter.com).mpg
(7.13 MiB) Downloaded 267 times
GenCode
Unread post by GenCode » 13 May 2022, 11:13
I have managed to add video now . here it is
Untitled 1.mpg
(12.2 MiB) Downloaded 267 times
Unread post by senso » 13 May 2022, 11:27
maybe it's time to read another time the tutorial ? :P
https://www.brainmodular.com/manuals/hh ... se-plugins
see
GenCode
Unread post by GenCode » 13 May 2022, 11:41
that's exactly how i it connected . did you see video attached for illustration ? i am trying to figure out why reverse action is not working
GenCode
Unread post by GenCode » 13 May 2022, 11:44
it appears that if audio engine is not on it doesn't do reverse action . thx for your reply it helped to find why it wasn't working
Unread post by sm_jamieson » 16 May 2022, 10:33
With the audio engine not on, lots of things don't work properly. This includes if you switched it on but the audio interface has failed to initalise etc. However you can set No Audio if you really need to.
GenCode
Unread post by GenCode » 27 May 2022, 09:08
Thx for the tip
Users browsing this forum: No registered users and 36 guests
