Hi
With Usine5 and BCF2000 (used for a long time without any problem)
BCF in bc mode as usual
My issue : in the midi devices panel, the BCF sometimes appears as BCF2000 (I want that), but other times as 3-BCF2000, or 5-BCF2000 (depending on the USB port where it's plugged) which obliges me to reassign my complete worspace.
Reseting, rescanning, devices / restarting Usine and BCF / changing the powering sequence / = don't give any predictible result
Any help on this issue ?
Problem detecting BCF2000
I had the same problem some time ago and Senso resolves it by adding in Setup > Midi > Midi options > memorize device name in learn.
Uncheck it and Usine will only keep controllers , channel numbers for your assignations.
It should work I guess
All the best
All the best
Hello Gilsornette
Thanks for your response (and sorry for my very late feedback) : yes, unchecking "memorize device name in learn" makes my BCF work whatever its name is when I plug it.
So thank you my problem seems to be solved.
Users browsing this forum: No registered users and 142 guests
