Setting side chain input for FabFilter Q3
Ariajazz
Unread post by Ariajazz » 02 Oct 2021, 06:01
Hi all. I'm trying to do a match EQ curve of two different audio sources using FabFilter Pro Q3 equalizer. For this Pro Q3 needs to listen to the REFERENCE audio through a side chain input. In most DAWs you just create an AUX send to the plugin (Pro Q3) and it will recognize and listen that audio source as the side chain input. How do I do it in Usine , in other words how do I create an AUX send recognizable by Pro Q3 as a side chain input?. I would like this to happen within a patch.
Thanks in advanced
Unread post by cmodica » 02 Oct 2021, 10:42
I think there is two more audioIN in the plugins module dedicated for side chain input.
So you can send A bus audio in these AudioIN.
I patched something like that long time ago with a compressor. I am not in the studio but i try to find this patch as soon as i open HH.
Ariajazz
Unread post by Ariajazz » 02 Oct 2021, 16:06
Thanks for replying. It did work, I always wondered why some plugins showed more than two (L&R) inputs. These extra inputs work as side chain inputs in some plugins. Thank you very much for your help.
