Hello again,
For a student work I'm doing I would to design some kind of drawable sonic panel (similar to penbox in motionkit).
Is there an "easy" way to build something similar in Usine?
Thanks a lot,
Uge
Draw in Usine
Hi Uge,
you can open the penbox workspace in Usine to see how it works. Most of the MotionKIt workspaces are available with the addons or your can download the old version "MusineKit 2.31" to get it : https://www.brainmodular.com/motionkit/ ... -to-action
Nice tip! I'll check later, thanks a lot!
