Trigger a sample by receiving the exact same value twice (or more)
creal
Unread post by creal » 04 Jun 2021, 14:43
In the scope of a big project that involved a lot of different things (which is about to end after 2 years of work, but I have big GUI bugs for the moment... I will contact the support by mail directly), I have to deal with receiving UDP messages based on RFID scans. I am okay with that and I interpret the messages (which are arrays) well.
I only keep one value of the received array. This number (ex: 104) triggers a sample by selecting a file number of a sampler less 100 (ex: 104-100 = 4 = 5th file of the sampler).
My problem is that for some of the numbers (101, 102, 106, 107), people can scan the number twice (ex: 101 -> 101) and the sample must be triggered, which does not work with the enclosed racks. It only works when we have a number between (ex: 101 -> 102 -> 101).
I apologize for the enclosed project because I tried to reduce the whole workspace in order to keep only useful things but some patchs may look messy to you. I can't have attached audio files as well because of rights.
I can develop or precise anything if necessary, or even rearrange the workspace (I just don't have much time for doing that today).
Thank you in advance,
creal.
RFID problem.wkp
(473.9 KiB) Downloaded 165 times
creal
Unread post by creal » 09 Jun 2021, 22:30
Re,
For the ones who are interested in, I found a workaround (not ideal but it works) by receiving a useless value (255) after each assignable value (ex: 101 -> 255).
creal.
Users browsing this forum: No registered users and 82 guests
