Button controlling two switches
Hi all. I need a button that can perform the following task: When the button is clkicked once it engages (turns on) a switch A and when the same button is clicked for a second time turns off switch A and turns on switch B (a secondary one).
Thanks in advance.
Thanks in advance.
Hi Ariajazz
Here is a simple patch, but there are many ways to do it.
You can also try the "group" option with many switches.
Hi rigsbt, thanks a lot for your help, the patch works like a charm but now I need a way to turn off switch B from a another button (a second one). I have try several things with no success.
Thank You.
Thank You.
You have to deal with "pass if change" module.
In this example, you can turn off switch B by clicking on it or using the button "set off B".
Thanks again for your help. I tried that before but thought it had to do with "TOOGLE" function in the switch. Now I get the idea about "SET ON and SET OFF" that were not present in old USINE v5 which I have use extensively.
Hello. Sorry I'm bothering again. The "set off button B" worked fine but there is a little problem: Button A has to be clicked twice to turn on switch A again. This is an issue since this button A is intended to be engaged by a cc midi message and it will only happen once at a time. Any idea on how to fix this?
connects the output of "set off B" to the reset input of the fader
Users browsing this forum: Google [Bot] and 33 guests
