Motionkit
Motionkit
Unread post by Gilsornette » 13 Nov 2020, 18:32
Is there a way to edit Motionkit's patches inside Motionkit interface or should I save them and import them in Usine to do some modifications?
Thank you
Unread post by rlgsbt » 13 Nov 2020, 19:30
Hi Gilsornette,
If you want to edit Motionkit's patches, you have to do it via Usine.
Some module will probably miss (not yet implemented in HH4), but you can also edit the older version of MusineKit without problem.
Unread post by Gilsornette » 13 Nov 2020, 22:20
Thank you for your quick reply.
I've imported PathGroove in Usine but it doesn't start reading (moving), do you have an idea about what I'm missing?
Unread post by rlgsbt » 14 Nov 2020, 07:57
For me, Path Groove works perfectly on HH 4.1.201104 (win64). The movement come from the "trajectory module" and a ramp.
You also can move the ball with 2 BUS X and Y (look at the XY pad).
Unread post by Gilsornette » 14 Nov 2020, 11:12
I'm using the same version of Usine ( also Win 64) but something is going wrong.
I'll have a look again. Thank you
Unread post by Gilsornette » 14 Nov 2020, 11:28
So, I've tried to save patches, rack and workspace, and then import them in Usine , but anytime it's not working.
Clicking on the window makes samples boxes disappear.
Some faders values are not correct. i.e tempo is 0 to 1, also for sample's fader.
Unread post by rlgsbt » 14 Nov 2020, 18:01
Well, I don't understand why you have to save patches, rack and workspace. If you open the original workspace on HH4 (from : \MotionKit Windows64 1.0.201013\Deploy\b - Workspaces\Path Groove.wkp) it should work !
Have you also tried to open the Musinekit version (ie. Homing Pad) ? from addons or directly from \MusineKit_Windows_2.31\Deploy\b - Workspaces\Homing Pad.wkp
It's quite the same wkp.
Unread post by Gilsornette » 15 Nov 2020, 15:34
If I open the workspace from Motionkit directory it works correctly.
It solves my problem, thank you!
Unread post by Gilsornette » 15 Nov 2020, 15:37
Another question, but maybe I should write a new post...
Is it possible to download PoseNet, and to run it offline?
Unread post by rlgsbt » 15 Nov 2020, 17:19
No, you can't...
...but it work anyway offline with the cache memory of your Internet Navigator ;-) if you ran it online before
Unread post by Gilsornette » 15 Nov 2020, 18:03
Thank you, that's a very good info I didn't know this.
I return to my previous problem. Path Groove is correctly running when loaded from Motionkit directory but it's not the case for some others.
E.g. Ringtone, additive, droid... Some data values are 0 and should be something else (Const, / amplitude in Droid...) , so the patch is not running correctly
Unread post by rlgsbt » 16 Nov 2020, 07:15
Some module are not yet implemented in HH4. but most of these wkp were already present in MusineKit 2.31 (additive/addix). The old one should run (but without motion detection)
Unread post by Gilsornette » 16 Nov 2020, 08:49
I was particularly interested in motion detection:-). No way, I'll use the old ones.
Thank you for your quick replies
damstraversaz
Unread post by damstraversaz » 19 Nov 2020, 08:35
that's a really nice project, congratulations.
The possibility to use it offline is really a must have in my opinion. Especially with students ( computers in music conservatory and school are often offline)
Users browsing this forum: No registered users and 25 guests
