Retrieve Section Titles via OSC ?
Unread post by cmodica » 05 Nov 2020, 14:11
I saw a "send grid sections info" option in the network settings. Does this allow to retrieve Section Titles and Numbers on an external device via OSC?
if so, how to do it?
If not, is there a way to do this?
Thank you very much.
Unread post by nay-seven » 05 Nov 2020, 15:05
something like this ?
Unread post by cmodica » 06 Nov 2020, 12:44
OK, simple.
Thank you, i will test.
See you.
Unread post by cmodica » 30 Aug 2022, 10:55
hi all.
I ask about it 2 years ago, but i don't remember how to send section title to Touch OSC with HH 5.1.211124 ?
I can manage fader, button, etc. but impossible to find how to send text to touch OSC ?
Unread post by senso » 30 Aug 2022, 18:22
did you try the OSC-send-text module ?
Unread post by rlgsbt » 30 Aug 2022, 18:29
like that.
For TouchOSC, the default host port is 8000 in Usine
in touchOSC editor, you have to create an OSC message in the text field :
Unread post by cmodica » 31 Aug 2022, 11:56
Thank you, it work fine with the OSC-send-text module.
In touch OSC i can configure the Incoming Port and Outcoming Port. But in HH I can only configure one port.
So i configure the same port for in and out in touch OSC. Is it OK ?
Thank you ?
Unread post by rlgsbt » 31 Aug 2022, 18:27
Dans usine, le port ouvert 2002 sert à recevoir les données. Par contre, il faut choisir le port 8000 dans les modules OSC pour envoyer vers touchOsc.
Chaque programme a ses ports d'entrées et de sorties et ils peuvent être changés si besoin
Unread post by cmodica » 01 Sep 2022, 22:00
Ok. J’ai compris.
Merci beaucoup.
