Touch OSC Bridge
Touch OSC Bridge
Unread post by cmodica » 11 Oct 2020, 16:18
Did someone work with Touch OSC Bridge ?
This utility allows you to use Touch OSC as a Midi control surface. Touch OSC Midi then appears in the Devices.
It seems to work. I can do Midi learn from Touch OSC on my Iphone. However, it is impossible to send Midi Out.
I have activated Touch OSC MIDI OUT in the general settings. I put the Touch OSC OUT device in the output of the rack, I tried to configure it as a motorized control surface. But no MIDI information comes out of Hollyhock.
Has anyone ever experienced this problem before?
Is it a bug from TouchOSC Bridge for Mac OSX ?
It's a pity because it would save me from creating OSC Sends for feedback to the Iphone.
Thank you very much.
Unread post by nay-seven » 11 Oct 2020, 16:28
Don' t have Iphone , but will test on android
is there a reason you don't use direct OSC ?
i test Osc feedback for each version we provide and it works here
Unread post by cmodica » 11 Oct 2020, 16:38
I need feedback on my Iphone. For example, I activate a switch in HH and a LED lights up on my Iphone. And vice versa.
I don't know how to get this feedback simply via OSC.
This is not a TouchOSC bug, because everything works fine with Live.
Unread post by nay-seven » 11 Oct 2020, 16:47
ok, just test and it works here with last Usine version on Mojave system
Have you set both the fader and the device Out TouchOSC Bridge as motorized ?
Unread post by cmodica » 11 Oct 2020, 16:54
YES !! Thank you.
I had forgotten to set the device out TouchOSC Bridge as motorized !!!
Unread post by nay-seven » 11 Oct 2020, 16:56
cool, have fun !
