Sampler with loop start locator different from start locator
creal
Unread post by creal » 02 Jul 2020, 21:53
After trying to achieve a simple patch for many hours, I give up and come to ask your help.
I would like to create a sampler that start from 0 (beginning of the sample) and goes to a X value (anywhere in the sample, it could be controlled by a fader by the way). Then it would loop from X to 1 (end of the sample), X to 1, X to 1, etc. without looping from the beginning.
I tried different options but I think the following one is the simplest: use one fader and tell to the sampler: "when you reach the position indicated by the value of the fader, move your start point to this marker value"
But I can't get it worked. I attached my patch with this message. I hope it will be useful.
Thank you,
creal.
Sampler loop.pat
(46.32 KiB) Downloaded 383 times
Unread post by SylvainT » 03 Jul 2020, 19:34
Et zou
A little tricky, but it works
Sampler loop.pat
Sampler Looper V02
(46.08 KiB) Downloaded 415 times
creal
Unread post by creal » 04 Jul 2020, 10:53
SylvainT wrote:
03 Jul 2020, 19:34
Et zou
Sampler loop.pat
Thank you very much Sylvain. It's exactly what I was looking for. I admit that it was too tricky for me :)
I just wonder one thing: is it possible to see a vertical barline where the loop point is, please? It will move accordingly to the fader position.
creal.
PS : your idea about putting an "0 to 1" after a ">=" is nice. I will use it for other patches
Unread post by SylvainT » 04 Jul 2020, 13:51
Sampler loop.pat
Sampler Looper V03
(44.32 KiB) Downloaded 402 times
joffo78
Unread post by joffo78 » 04 Jul 2020, 21:59
Hi Creal .
have a look at my tutorial :
https://www.youtube.com/watch?v=zb3QRObpm20
I made a player that do exactly what you want with 2 markers.
You even set a different end point et stop the loop to read smootthy until the end of the loop.
You'll find on the description the link to download it
creal
Unread post by creal » 06 Jul 2020, 19:55
SylvainT wrote:
04 Jul 2020, 13:51
Sampler loop.pat
Thank you :)
creal
Unread post by creal » 06 Jul 2020, 20:05
joffo78 wrote:
04 Jul 2020, 21:59
Hi Creal .
Hi Joffo,
I subscribed to your channel one month ago but never took the time to look at it seriously. Your content about both samplers will be very useful to me. Thanks a lot.
One optimization about the first sampler would be to select a crossfader curve, like Reaper (or any other DAW) provides: linear, expo fast start, expo fast end, etc.
But in its current state, it's already a huge step forward for me and the project I'm at the present time :)
joffo78
Unread post by joffo78 » 07 Jul 2020, 00:17
Hello.
Thanks a lot for your feedback.
have a look on my update : https://u.pcloud.link/publink/show?code ... w037DDSb8X
you'll find a kind of curve on this way
creal
Unread post by creal » 09 Jul 2020, 21:04
joffo78 wrote:
07 Jul 2020, 00:17
Hello.
Waou, that's super useful. I added a combo box for selecting the kind of curve (to both samplers). It's perfect. Thanks.
Users browsing this forum: No registered users and 119 guests
