"if you get this message, send this one."? :)
laserbeak43
Unread post by laserbeak43 » 12 Jun 2006, 19:25
hi i want to use my drum pads to trigger certain areas in a sample. in the sampler. for instance, pressing note 60 on the pad will trigger position 0% and using 8 of the pads, have it increment up to 100% in increments of 12.5% how would i do this?
Unread post by senso » 12 Jun 2006, 21:24
all you need is a "data/selector" module/
Transform your note on 60-68 into a range 1-9 with a math/sub (substract 59 to the input note on)
In the selector, put in the first data line 0, 12.5 in the second, and so on.
Connect the math/sub out to the "select" in of your selector.
Connect the selector out to the "pos" in of the sampler.
that's all.
laserbeak43
Unread post by laserbeak43 » 13 Jun 2006, 02:27
senso wrote:all you need is a "data/selector" module/
that's all.
i love usine!!!
Users browsing this forum: No registered users and 27 guests
