Mixing MIDI downstream the 'seq multi'?
Hi again
In a MIDI patch, in sequencer mode, why is it not possible to mix MIDI downstream from the 'seq multi'?
It sends continuously a CC123 that cannot be filtered by a 'midi filter' set to 'ON/OFF/BEND' but by at least three 'midi filter' respectively set to 'NOTE ON', 'NOTE OFF' and 'PITCH BEND' (plus eventualy a CONTROL CHANGE, plus...).
Do all the MIDI mixes have to be upstream from the 'seq multi' ?
Thanks!
Thanks!
vincent michel
composer & novelist
composer & novelist
Nobody to help me? Is it a stupid question?
vincent michel
composer & novelist
composer & novelist
I'm not sure I understand your pb!
could you explain (for a midi newbie like me...)
Ah-ah-ah! what are we if you're a newbie?senso wrote:(for a midi newbie like me...)
Default patch (almost...) with upstream midi mixing:
Downstream midi mixing:
Since the 'seq midi' sends a cc123 continuously, the VSTi cannot be played via the Midi In... except very strange percussions!
My question is: how to make it work this way? (or stop this cc123)
I hope I'm less confuse...
Thanks!
V
vincent michel
composer & novelist
composer & novelist
strange , cause it works fine here
and controller 123 is " all notes off " so maybe normal
but
where did this controller came from...? seems like you have a ghost here
seriously , maybe active the "trace in " in your midi in setup..?
but
Thanks Yan, "trace in" is active, and shows nothing!
Try just to put a 'Midi Filter' after the 'Midi Seq' and it shows that the cc123 sends non stop (red led "send" always lit)... with nothing before.
I always hated ghosts, specially #123!
vincent michel
composer & novelist
composer & novelist
sorry , i've replicate your patch with an other vsti , insert it in sequencer and no problem here...even with a midi monitor behind...
i'm under vista sp1...?
Thanks for help, Yan, why to be sorry?nay-seven wrote:sorry , i've replicate your patch with an other vsti , insert it in sequencer and no problem here...
No Vista here for the moment, but XP pro. No matter I think.
One difference is that I first inserted the patch in the sequencer, since it's a midi file, and then change the patching.
Doing your way (not in sequencer for patching), I just noticed a detail: the Piano Roll sends this cc123 only when Sync is OFF. Seems to be necessary to prevent hanging notes when switching Sync OFF.
Any idea to bypass this inconvenient?
vincent michel
composer & novelist
composer & novelist
hé hé , was just sorry for you vincent..
ok , i've test your way : insert a midifile in the sequencer , add a midi in module...no problem
maybe check the midifile itself...? or try with an other midifile..?
The same for all of them. I made them: there is no cc123 in the CC I use!nay-seven wrote:ok , i've test your way : insert a midifile in the sequencer , add a midi in module...no problem
I think it just comes when Sync is OFF, I'm working on that right now.
This idea of sending a cc123 when the sync goes OFF seems logical, but I think that there's no need to send it continuously (repeated), once would be enough...
vincent michel
composer & novelist
composer & novelist
The 'seq midi' module is only maintained for backward compatibility. Use the Piano roll instead.
The CC123 is 'all not off'. Maybe the 'Seq midi' is buggy now, but I'll not spend time on this module, since the pianoroll does a better job.
Thanks Olivier.senso wrote:The 'seq midi' module is only maintained for backward compatibility. Use the Piano roll instead.
OK, but the 'Seq midi' automaticly comes up when a midi file is drop in the sequencer (UsineProStandAlone3.63c).
PS : Yes, I now well know what cc123 is!
vincent michel
composer & novelist
composer & novelist
oups ... I was talking about the 'midi file player' sorry. Sometime Usine is so big that I lost myself...midi file is drop in the sequencer (UsineProStandAlone3.63c).
I'll take a look on the CC ghost problem.
Thanks!
Note that this 'all notes off' is logical, I'm OK with it and you should keep it. It is NOT a ghost.
But it is unnecessary - and very bothering - to send it as long as the synchronisation is of.
Only one cc123 should be fine?
vincent michel
composer & novelist
composer & novelist
