Usine Resolution behavior question.
dmitriyc
Unread post by dmitriyc » 16 Apr 2019, 22:44
Hey All!
So I noticed when you drag a workspace instance of Hollyhock 3 from one display to another, that it changes resolution (say if you have a laptop that's 1366x768 and a TV as a secondary input at 1920x1080). Is there any way I can take that information and use it as an input?
Thanks.
x.iso
Unread post by x.iso » 16 Apr 2019, 23:03
If you're using Windows 10, then it's probably just automatic DPI scaling, not really controlled by Usine
dmitriyc
Unread post by dmitriyc » 17 Apr 2019, 03:05
follow up question then: does Usine itself give any indication that it knows if its on the first or the second display?
Users browsing this forum: No registered users and 32 guests
