input quantization question
laserbeak43
Unread post by laserbeak43 » 07 Jun 2006, 18:13
is there any way to delay a signal by 8ths?
i was thinking maybe some sort of if statement that says if the input signal isnt triggered at the nearest 8th of a beat then delay it to the next beat. using the modulous operator and milliseconds since at 180bpm a beat is 333 milliseconds modulous would send how much time the delay would need to wait and release the signal at 0.
laserbeak43
Unread post by laserbeak43 » 07 Jun 2006, 19:28
is there anything that can delay a signal for a specified duration of time?
laserbeak43
Unread post by laserbeak43 » 07 Jun 2006, 19:58
i have a sync module
a mod module set by the syncs bar duration(333ms)
a count ms module with a duration of an 8th of a bar
wich is 41.625 ms
and a smooth module wich i'm trying to use to let a delayed message pass at zero. i'm using a button to try and trigger the sampler.
sync(bar dur) -> mod(A)
sync(bar led) -> count ms (start in -> count out) -> mod(B)
button -> smooth(in)
mod(out) -> smooth(smooth) -> sampler(start)
when i press the button nothing happens
click image for fullsize veiw.
Unread post by senso » 11 Jun 2006, 11:16
sorry,
I'm on the road, and it's hard to find the time to post an answere.
The solution is simple for buttons.
- Take a counter (ms) module.
- Set the, count duration to the quantize duration;
ie: the beat duration, the eighth note duration,..
- connect the output of the button module to the start count. Now when the button is pressed, the counting process starts, with a maximum duration set to the quantize time.
- take a "math/logical/and";
- connect the "counting" output of the counter to the "and" first input,
- for a beat quantize: connect the beat led of the synchro to the second "and" input.
- for a eighth quantize: connect the eight led of the synchro to the second "and" input.
the "and" out is the quantized version of the button.
Hope I'm clear.
laserbeak43
Unread post by laserbeak43 » 11 Jun 2006, 19:04
senso wrote:sorry,
Hope I'm clear.
thanks that sounds somewhat clear. got time to make a screenshot? :)
laserbeak43
Unread post by laserbeak43 » 12 Jun 2006, 07:32
laserbeak43 wrote:
senso wrote:sorry,
Hope I'm clear.
seems to be working!! gonna sneak my midi gear upstairs and double check! thanks!
laserbeak43
Unread post by laserbeak43 » 12 Jun 2006, 14:44
sorry to cross link but i think i've found a bug.
please check http://sensomusic.com/forums/viewtopic.php?id=103
