Maschine (Feedback on Hardware, need State: On/Off only)
lytz1
Unread post by lytz1 » 17 Jan 2019, 19:58
Hey there.
Yeah, me again... :D
did someone of you get Maschine to reflect on/off (0/1 or 0/127) states from HH3?
I can't get it to work.... I just need toggles. So that if something is ON, Maschine LED tells me it is ON.
Just static states, nothing moving, no sequencer running or anything.
Shouldn't be that hard but I still can't get it to work...
Any help on that one?
tL.
drakh
Unread post by drakh » 18 Jan 2019, 16:04
i have something like this but for akai apc mini ...
drakh
Unread post by drakh » 18 Jan 2019, 16:06
best way for this should be to have midi learn for midi out of element.. i requested this feature few times :/
now there is a swtich on element when using midi learn "motorized" but it sends data to device only if state is changed from GUI :/
lytz1
Unread post by lytz1 » 18 Jan 2019, 17:12
I'll check it out for the APC Mini. Maybe I can see something there.
Thanks.
Blaakk
Unread post by Blaakk » 02 Feb 2019, 20:34
Not sure if this'll help towards what you're after....
http://www.sensomusic.org/forums/upload ... OUT.device
After using the 'controller editor' app to set the pads to send continous controller messages, and also setting all pads' 'LED On' to 'For MIDI In' and the color mode to 'HSB', then for each CC number (Ie each pad), the Hue, Saturation and Brightness values can be sent from Usine independantly via channels 1, 2 & 3 respectively.
So in your case, after setting your Hue and Sat, you'd just swap the Brightness knob for a switch with an on value of 127.
Maybe a bit much, (another color mode may be more straightforward), but it works. This is the only color mode I've used.
Blaakk
Unread post by Blaakk » 02 Feb 2019, 22:19
http://www.sensomusic.org/forums/upload ... T_2.device
Click the gear icon / popup on the device header to set CC num offset (minus 1) to match your starting pad number (In this case, my pads are set to CC 12 - 27, so my CC offset is 11).
lytz1
Unread post by lytz1 » 03 Feb 2019, 00:52
Thanks man, this is cool.
I already had a solution for the on/off states in both directions.
These were the most important ones for me.
But I can use this as well for sure, thanks again.
BTW: Still have Maschine MK1 here...
Looks awfully bad after years of traveling, but it is still working... ;)
Best,
tL.
Users browsing this forum: Google [Bot] and 9 guests
