Change number of channels on existing sampler-recorder?
steevhise
Unread post by steevhise » 18 May 2018, 06:30
I'm trying to alter an existing patch, making it stereo instead of single channel. The guts of it is a sampler-recorder module. Is there no way to change the number of channels on the sampler-recorder module? When making a new one I see it gives choices for how many channels, but I see no way to change that in an instance of the module that's already in the patch.; It's kind of driving me crazy...
thanks,
steev
Unread post by oli_lab » 18 May 2018, 07:49
you have to change each module one at a time...
What I usually do is using constant modules plugged into the parameters I want not to be lost,
just pull a link from the input you want the value to be saved then choose "constant" in the contextual menu
then recreate the modules
Unread post by nay-seven » 18 May 2018, 09:06
You can also simply drag the same module over the existing one, will turn to red, then ask you the channel number you need.Then you'll only need to recreate the missing inputs/outputs .
damstraversaz
Unread post by damstraversaz » 18 May 2018, 10:03
nay-seven wrote:You can also simply drag the same module over the existing one, will turn to red, then ask you the channel number you need.Then you'll only need to recreate the missing inputs/outputs .
oh, that's a very nice tips !
steevhise
Unread post by steevhise » 18 May 2018, 20:29
Excellent! Thank you!
