I'm having trouble sending midi to the IAC bus.
I tried to "Add midi Out" but that didn't work.
there is no IAC Bus device listed anywhere.
Thanks!
send midi to IAC Bus (MacOS)
Iac is a device, once activated in your Mac Midi setup (must be lighted)
a refresh in the MIDI tab of Usine will let you activate it and it will appear in the devices panel. Now you can drag it in the rack output as a normal device.
Hmm, I'm not seeing the same MIDI tab as you
Yes, you use version 139 , you can update to the last one, the 169.
but i admit there's a strange thing because you don't have the rescan and reset buttons, try to download a fresh version.
( don't use the import old settings in a first time)
