control button in record window, and also: what are bindings?
Unread post by woodslanding » 05 Mar 2018, 07:37
There's a control in master which will open the record window, just like from the toolbar....
But what I'd really like is the ability to just control the record button in that window via my own button in the IB.
Maybe there is a way to control the button? but I haven't found it.....
Now I see I can learn on the button, although what I want to learn from is a regular button in the IB, not midi or keyboard. I see the binds, I have not used this feature. Could that be a solution?
A search on 'bindings' turns up 0 results in the manual. 'Binding' turns up 1, settings panel remote tab, but bindings are not explained there.....
So.... what are bindings, and how do they work??
Unread post by woodslanding » 05 Mar 2018, 07:49
Ahh. solved.
Needed to search on binds! Also, the settings remote panel help page did not load completely!
Using a binding worked perfectly, feature request averted!
cheers,
-e
Unread post by woodslanding » 05 Mar 2018, 08:00
Hmmmm. Slight complication.... when I set up this bind (from a buss named GLOBAL RECORD) it ALSO sent a signal to an internal BUSS of mine called 'REC', thus turning on my loop recorder as well. Apparently that is the text string that Usine uses for this button or something like that? I'm not sure I understand what's going on under the hood.
I renamed it to RECORD, and all is well for now.
Is there a list somewhere of all the internal busses for usine, so we can avoid conflicts? There is no 'REC' in the binds list now, but a receive named 'REC' will get data, even though I created no send of that name.
I could see this causing problems that might be much harder to debug. In fact, I wonder if some of the strange buss behaviors I have encountered over the years could have been caused by something similar???
Any further explanation of what is going on would be very welcome!
thanks,
-eric
Unread post by woodslanding » 06 Mar 2018, 03:00
Okay, this is a bit of a problem. Just changed the icon for a button called 'Settings', and it also changed the leftmost icon in the details panel.....
I think we need a list of names to avoid using in our patches!!!
Unread post by nay-seven » 06 Mar 2018, 14:34
for your bus issue, you have to know Usine don't use internal buses this way, so names can't interfere.
About the button, can i have an example patch and screenshot ? not sure to understand
Unread post by woodslanding » 06 Mar 2018, 17:23
Sure.
I'm curious what it does on your machine. When I opened this wkp on my other machine, it also put the usine settings icon on MY button, which did not happen when I created the button on my laptop....
http://www.sensomusic.com/forums/upload ... nIssue.zip
It was easy to fix, I just renamed the icon to gSettings.png....
-e
Unread post by woodslanding » 06 Mar 2018, 17:27
nay-seven wrote:for your bus issue, you have to know Usine don't use internal buses this way, so names can't interfere.
Ummm.... so do you know what's happening here, then?
Unread post by nay-seven » 06 Mar 2018, 21:07
no idea for buses
for the button, as Usine don't know where is your personal icon, he looks in his own folder and found the settings icon ?
Unread post by woodslanding » 07 Mar 2018, 06:36
No--- other way around. Usine looked in MY folder for ITS icon!
This happened as shown in the screenshot without importing the wkp to another computer.
Although when I did open it on the other computer, my icon showed up in the usine panel, AND usine's icon showed up on my switch!
no big deal anyway....
