switch triggering a button
try the from 1 to 0 or from 0 to 1 modules in patching
or the "has changed" module if you want the button activated each time the switch changes state
THANK FOR REPLYING. It worked. What about the opposite - Trigger a switch by pressing of a button?, in other words: turn on a switch with a button
button -> toggle if wanna alernate. or connect to a switch 'set on' if wanna only set it on, never off
Ok guys sorry to tell you this but the "from 0 to 1 and/or 1 to 0" did not work for triggering a button with a switch, Any other ideas?. I'm stuck. Thanks all.
works perfectly, can you be more precise ?
Thanks Nay-seven for replying. I have a function that employs a milisecond counter, as far as I know the counter's START is activated by a button not a switch. I need to be able to start it by a switch, that's why I thought that triggering a button with the press of the switch could work but I don't find a way to do so.
Don't shout, share your patch...
Sorry for the inconvenience, I reviewed my work and I was patching erroneously 1 to 0 and 0 to 1 DO WORK. I appologize. Thanks to all.
good news !
Users browsing this forum: No registered users and 119 guests
