Midi clock receive on a device
Unread post by grego mondo » 11 Jan 2018, 17:46
Is there a way to activate (desactivate) the receive MIDI clock (or MTC) of a device in real time ?
Unread post by grego mondo » 11 Jan 2018, 19:29
Looking for an inlet
Unread post by nay-seven » 11 Jan 2018, 19:39
Currently no, maybe possible as suggestion ?
x.iso
Unread post by x.iso » 12 Jan 2018, 10:56
Recently I've come across same question. One way that worked for me, was switching on and off the midi output device itself (that sends the clock). The idea was to make a step sequencer that sends and interrupts clock output for SH-101 (which is connected through another device to convert midi into CV/gate), so it's internal sequence plays differently to make it groovy. So that worked, but it's tricky to also send notes in this situation, but I have idea for that as well. Anyway, I'll add suggestion for more straightforward way to do this.
Unread post by grego mondo » 12 Jan 2018, 12:28
I Thought of that way (disactivating the device) but I believe I dosen't works for input device, only for output ...
Unread post by 23fx23 » 12 Jan 2018, 15:10
maybe toglling from a mastersync (wich will use MTC) to local sync(that would not) might do the job as a workaround?
ie drop a local sync module and enable or disable 'active'. if off the patch syncs to master mtc, if on will use the local sync
Unread post by grego mondo » 15 Jan 2018, 13:54
I believe that would works for a patch or a rack but I'm trying to synchronise a wholke grid with more than 10 piano roll on one song and become slave and the next one ...
Users browsing this forum: No registered users and 123 guests
