Hi Guys,
Each time I apply poly (not apply and reset), the lovely layout which took so much time to set is squashed into a pile of icons in the corner of my patch. Is there's any way to avoid this ?
Best
Kenan
Apply Poly and layout
you can specify the position of the panel directly to inputs of the modules. then use the poly number module to shift the panels from one voice to another
Thanks Oli,
Thanks for your answer. I finally did it another way, I created a sub-sub patch in my sub-patch, I design the layout on the sub-sub patch and then I force reoganization on the sub patch...
Kenan
Kenan
well, there you go. Never thought of that. I might be able to use that, thanks!
plz share !
Users browsing this forum: No registered users and 144 guests
