LEAP how to add my own sounds?
Boe
Unread post by Boe » 17 Nov 2017, 22:21
Hi, I use LEAP on USINE3 and are quite excited by it. But... I would like to add my own sounds into the "drone", "grainplayer", "shots" etc. But I can't figure out how..?
Can anyone help me? Do you know about any tutorials that shows it? I can't find any.
Thank you so much in advance!
Boe
x.iso
Unread post by x.iso » 17 Nov 2017, 23:10
There's a setting icon in the patch header, it shows popup window and there click/tap show list and there's a list of samples that you can change and rearrange.
x.iso
Unread post by x.iso » 17 Nov 2017, 23:12
generally, where samples are used, they are usually pulled from list and there's either icon or button to show list of samples.
Boe
Unread post by Boe » 20 Nov 2017, 10:21
Thank you so much for your reply! I've already tried and couldn't make it work. I will try again.
Users browsing this forum: No registered users and 28 guests
