What is the reset command in HH3?
if an ui item got this fonction enabled, there usually is a little arrow on the toolbar (if displayed in item layout properties), or also a reset button on the menu, both will trigg a reset procedure of said module
Hello Scott,
The reset command is in the Usine Patch Settings module. You can have a command for resetting a whole patch. You can choose on each module of the patch if it can be reseted with the patch (and you can choose its reset value). Very usefull if you have a lot of control on a patch, total reset instantaneously.
Same thing with the random possibility...
Thanks SylvainT and 23fx23, What I'm looking to understand is how to send a reset command. Is there a "reset" module, or an IML command?
Regards,
Scott
Scott
many modules have a reset inlet ?
Thanks, nay. So no global, "reset all" command?
Regards,
Scott
Scott
Users browsing this forum: No registered users and 82 guests
