Autopitch formula to fit sample to time/tempo of project (NOT Grain)
lytz1
Unread post by lytz1 » 20 Jun 2017, 02:16
Guys, I am looking for a way to pitch samples in the normal sampler automatically up/down to fit the project tempo.
Audiomulch can do this automatically so I guess there HAS to be a way to do this in HH as well. Would save me a lot of time.
(I want the pitch to change when changing tempo, I can't use timestretch/grain for what I have to do. In one case, for example, I need the sampler to play half-tempo of project-tempo resulting in playing back the loop an octave down.)
See below: Senso wrote this in 2006. I think this is exactly what I need but I have no idea how to patch this, because of the (...)'s.
Anyone an idea?
Thanks guys,
tL.
SENSO:
I think that the question could be asked like:
I have a sample with a length (let's say length_ini);
What pitch should I play this sample to fit to another length, for example the cycle length (let's say length_final).
The pitch can be calculated with:
Pitch = 12*LN(Length_ini/length_final)/LN(2)
LN=Logarithm
You can use the Math/Trunc module to get a rounded pitch if you need it.
In the User Library you can find a patch called "Sampler Adapt Pitch" witch does this kind of stuff.
Unread post by oli_lab » 20 Jun 2017, 11:31
File uploaded: http://www.sensomusic.com/forums/upload ... 0pitch.pat
tell us how it goes !
lytz1
Unread post by lytz1 » 20 Jun 2017, 22:08
Hey Oli, thanks a lot!
looks good so far, I just need to get it in sync somehow.
Also, do you know why the output always gives TWO values? (The output after the last divider alternates
between a positive and a negative one.)
Best,
tL.
Unread post by oli_lab » 21 Jun 2017, 12:11
lytz1 wrote:do you know why the output always gives TWO values? (The output after the last divider alternates
Does not happen here
I did some mods :
it is log10(x) module to use, not ln(x)
you can use bar length or cycle length as you prefer
adding a sync
lytz1
Unread post by lytz1 » 21 Jun 2017, 23:37
Thanks again Oli, output is steady now.
Best,
tL.
Users browsing this forum: Bing [Bot] and 126 guests
